Cleaning PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2012, 04:39 PM   #1
"Old" Newbie
Rewards Points: 177
Cleaning PVC Pipe
I'm building some recycling tubes for monofilament fishing line..
I'd like to remove the red lettering from the PVC tubes.
Alcohol works not at all and brake cleaner not much better.
Any suggestions?
Thanks,
Rob
RCrosby257 is offline   Reply With Quote
Old 11-09-2012, 04:40 PM   #2
Rewards Points: 13,968
Mineral Spirits or Acitone
Old 11-09-2012, 05:02 PM   #3
DIY staff
Rewards Points: 7,174
Sandpaper?
Clear PVC primer?
ben's plumbing (11-09-2012)
Old 11-09-2012, 05:30 PM   #4
joed's Avatar
Rewards Points: 13,306
PVC cleaner. Make sure it is clear. Some of them are purple.
Old 11-09-2012, 05:52 PM   #5
"Old" Newbie
Rewards Points: 177
Cleaning PVC Pipe
Thanks All for the advice.
Are PVC cleaner and PVC primer the same?
They gave me two cans of Weld-On,
724 CPVC and P-70 Clear Primer.
Sounded from the directions like the primer would soften the plastic, yes?
If so, NOT what I want to remove the lettering.
Old 11-09-2012, 07:02 PM   #6
DIY staff
The primer etches the surface a bit--it does not leave it soft---so you should be fine---try a spot if you already own a can---
sanding works---that red printing is very thin---
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cleaning galv pipe threads Joe F Plumbing 6 09-30-2011 05:27 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
