Cleaning The Overflow Of A Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 01:03 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
cleaning the overflow of a sink
What is the best way to clean the inside of the sink overflow? I find whenever I run the water, I get a quick wiff of shaver hair smell, probably because some of it has managed to get into the overflow from the drain. I was thinking of filling the sink with javex or other cleaning product and letting it overflow into the hole, would this work?
Maybe even drain cleaner as it will foam and clean the inside better.
Old 08-05-2010, 02:18 PM   #2
Handyman
Rewards Points: 512
Hmm..never had cause to clean an overflow before Maybe put some baking soda down there and leave for a bit (helps get rid of odours) then rinse with hot water
canadaclub is offline   Reply With Quote
Old 08-06-2010, 07:51 AM   #3
Do not use drain cleaner, as it may break the sink. Install the stopper in the sink. Pour in one cup of household bleach. Slowly run either cold or hot water into the sink (to avoid splashing the bleach). Let it go into the overflow. Continue to run water until the bleach odor is gone. This should cure your problem.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
