Cleaning Off Oxidized Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 03:54 PM   #1
Rewards Points: 135
I'd like to get an idea if my pipe (domestic water) joints are still leaking by cleaning off some of the green gunk and checking back later. It looks like there was some minor seepage in places, but now looks sealed up (compression fittings mostly, but a little bit on solder work too). I see vinegar and salt being recommending, is this a good idea? Is a little bit of greenery on the outside of pipe okay or is it a sign that I need to toss the compression fittings and solder it up? No signs of recent leakage... Here is an example. Is this a candidate for re-do or should I just leave be?
smata67 is offline   Reply With Quote
Old 05-17-2010, 04:24 PM   #2
Rewards Points: 1,494
I would leave it be.
Are you sure that the greenery is due to water leaking as opposed to oxidation from leftover soldering flux together with condensation on the pipe over the years?
Old 05-17-2010, 04:43 PM   #3
Rewards Points: 135
The one showing the most oxidation is the hot and I don't have a trap, so I don't think it would be condensation. I did this 15 years ago, I can't recall if I wiped off the flux...
Old 05-17-2010, 05:22 PM   #4
Civil Engineer
Rewards Points: 4,694
If I remember my chemistry correctly, the green is copper oxide. Copper will oxidize in the presence of air and water, so if there was leakage that would promote oxidation ==> the green stuff. Flux is somewhat acidic as I recall, and acidic conditions also promote oxidation. The green oxide does come off nicely with vinegar and salt, however removal of the oxide does not prolong the life of the pipe, and serves little purpose except cosmetic.
You should be able to tell if the pipe is leaking by placing a paper towel on it. In the summer, my cold water pipes condense moisture, which confuses the issue of whether the pipe is leaking or condensing, but in the winter there is no condensation, so any water would be leakage.
Copper Pipe Turning Green marcoj32 Plumbing 27 09-22-2014 10:10 PM
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
Underground copper pipe protection Stephen S. Plumbing 8 01-23-2010 07:16 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
12/2 wire in contact with Hot water pipe (copper) - Dangerous? Tryvidy Electrical 6 04-21-2009 07:35 PM
