Cleaning Galv Pipe Threads - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2011, 04:56 PM   #1
Joe F's Avatar
Rewards Points: 294
Cleaning galv pipe threads
I'm replumbing a basement slop sink. I removed the old galvanized waste line and I'm going to replace it with PVC. The problem I have is that the threads in the wye are pretty gummed up. What is the best way to clean them so that they will accept the PVC male adapter. BTW, it's inch and a half pipe, if it matters.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 09-28-2011, 04:58 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Wire brush ?
Old 09-29-2011, 07:14 AM   #3
Joe F's Avatar
Rewards Points: 294
I tried a wire brush and had marginal results. It's a 60+ year old house and the stuff in the pipe is pretty hard. I was thinking more along the lines of a solvent, if there is such a thing for this purpose.
Old 09-29-2011, 08:22 AM   #4
Rewards Points: 152
Triangular file?
burnt03 is offline   Reply With Quote
Old 09-29-2011, 08:23 AM   #5
Rewards Points: 1,596
Is it rust or grease? If grease, perhaps dish soap and wire brush or maybe wd40 or even brake cleaner and brush. If rust, wire brush.
bob22 is offline   Reply With Quote
Old 09-29-2011, 11:09 AM   #6
Lightfoot's Avatar
Rewards Points: 272
An old time plumber buddy of mine (RIP), once told me that anti-freeze (which contains ethyl glycol) will soften old hardened pipe dope. I have no idea if it will, i have never tried it. Since it's going in a drain pipe (and not a supply), i wouldn't be afraid to try it.
Lightfoot is offline   Reply With Quote
Old 09-30-2011, 05:27 AM   #7
Joe F's Avatar
Rewards Points: 294
I wound up using a wire brush and some CLR. Wasn't perfect, but good enough to get the fitting threaded in solidly.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Lost pipe down well hntrak Plumbing 3 09-01-2008 08:17 AM
