Cleaning Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2013, 08:23 AM   #1
Rewards Points: 236
cleaning copper
i just pit a bunch of copper in for my kitchen sink. what do i use to clean the pipes so they don't turn green ? if it can polish them up a little, all the better.
Fix'n it is offline   Reply With Quote
Old 11-02-2013, 08:47 AM   #2
Rewards Points: 13,750
Not going to happen.
In fact trying to clean it off will cause it to corrode faster.
Not having any leaks, and 50% or les humidly in the house is all you need to not have it turn green.
Old 11-02-2013, 09:28 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
Wipe your fittings with soap and water to remove the flux residue.
You can paint them if you want.....
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (11-02-2013)
Old 11-02-2013, 10:05 AM   #4
If you clean off the flux, as mentioned, you won't have a problem. If it is exposed and you just want it nice and shiny, then polish it up and use clear shoe polish on it.
ask tom is offline   Reply With Quote
Old 11-02-2013, 01:06 PM   #5
Rewards Points: 6,652
They turn green, from any chemicals stored under the sink, not just because. I have Copper under my bath & Kitchen sink, never have had any issues with it turning Green. If it does, it will do it at the joints, before the whole section.
Old 11-02-2013, 02:29 PM   #6
Rewards Points: 1,292
Wipe them down with a couple of squirts of WD-40 on 0000 steel wool.
Old 11-03-2013, 07:13 AM   #7
Rewards Points: 236
thanx fella's.
i did wipe them down. i will do it again with pb blaster.
Old 11-03-2013, 07:14 AM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,.... When I redid the bathroom in my rental, 'bout 8 years ago, the shower pipes were gonna be "Exposed", so I cleaned 'em up with a green scotch pad, 'n painted 'em with clear Rustoleum enamel,...
So far, they're still lookin' like clean shiny copper pipes,...
Bondo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bondo For This Useful Post:
plummen (11-03-2013), TheEplumber (11-03-2013)
Old 11-03-2013, 07:18 AM   #9
Rewards Points: 582
what is your purpose for doing so????? ben sr
Old 11-03-2013, 07:59 AM   #10
Rewards Points: 236
there is a good bit of pipe exposed under the kitchen sink. i just don't want it to become unsightly.
Old 11-03-2013, 08:43 AM   #11
Bill Kearney
Rewards Points: 1,174
It's under a sink, when is that area NOT unsightly?
As for keeping copper shiny, I have a copper mailbox that I put what amounts to musical instrument grade clear coat on it (I have a can left, but it's packed away otherwise I'd mention the name). I applied six coats. Six years later, even after being out in full sun and the elements (south-facing, no shade) it still looks brand new. I'll probably put on a fresh coat or two before reinstalling it at the new house. So it "can" be done, but for under a sink? Why bother?
wkearney99 is offline   Reply With Quote
Old 11-03-2013, 09:12 AM   #12
Master Plumber
Benplumbing's Avatar
I guess I wouldn't spend too much time seeing that they're going to be underneath / inside a cabinet. No matter what with copper it will eventually dull the look. But yes after soldering wipe Fittings with wet rag to clean the excess flux off.
Benplumbing is offline   Reply With Quote
Old 11-03-2013, 09:32 AM   #13
Rewards Points: 236
when was the last time you seen it run this way ? yeah, thats what i thought
i just want to keep this from looking ugly. it doesn't look bad now.
btw. dishwasher just showed up.
The Following User Says Thank You to Fix'n it For This Useful Post:
jmon (11-03-2013)
Old 11-03-2013, 09:37 AM   #14
PoleCat's Avatar
Rewards Points: 1,646
Nothing wrong with a man taking pride in a smart looking plumbing job.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Fix'n it (11-03-2013)
Old 11-03-2013, 05:11 PM   #15
Rewards Points: 1,298
Please tell me that trap is not laying on it's side.
danpik is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 06:47 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Internal copper pipe cleaning handyless man Plumbing 2 06-22-2011 06:52 AM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
