#31 |
clean out cap pipe is stripped
If you fixed the problem with the cleanout threads, i'd clean around the tiny leak real good with a dremel tool or grinder and epoxy the leak, use a two part epoxy and mix it well, it should outlast the pipe. Clean an area about an inch around the leak to bare metal and you should be fine.
| The Following User Says Thank You to Amazingglazier For This Useful Post: | Ravenworks (04-27-2012) |
#32 | |
retired elect/hvac/plumb
clean out cap pipe is strippedQuote:
The pipes sit down inside the hubs,it would be tough to take apart without cutting,although I do know of a few ways to remove that fitting and retaining bottem hub its kind of risky if you dont do it every day.
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
| Display Modes | |
| How To Solder Copper Pipes | Termite | How To Guides | 69 | 11-13-2012 01:20 PM |
| Leaking drain pipe under kitchen sink | dethun | Plumbing | 20 | 09-26-2012 08:30 AM |
| Need to close off or move a vent pipe & drain that goes to nothing | mystic_cobra | Plumbing | 2 | 04-18-2011 09:14 PM |
| removing Cast Iron drain pipe | jimmyfloyd | Plumbing | 1 | 01-04-2011 04:47 PM |
| Exterior Furnace exhaust vent pipe | NeedHomeRepair | HVAC | 1 | 12-20-2010 06:17 PM |
