Clawfoot Tub Woes Continue - Found Possible Solution - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2009, 04:11 PM   #1
clawfoot tub woes continue - found possible solution
So, I had an earlier thread about dealing with compression fittings. I'm pretty sure I destroyed one of them and can't reuse the supply line.
My old tub faucet had these "bathcock couplings" (AKA "leg tub ells," or "bathcock ells"), that i decided i wanted to reuse on my new faucet. They don't fit! I have a strom plumbing faucet with 3/4" male threads sticking out the back.
Here's what I'd like to do:
Screw on a 3/4" copper to 1/2" copper adapter, bang on a street 90, then copper directly down from there, just hardline the entire thing with copper right to the faucet. I assume the only downside to this is that to later remove the faucet (should last a lifetime) someone would have to unsweat that one joint to get it apart.
This would get rid of my leaky compression fitting, ugly chrome double offset supply lines, and make the whole assembly look much cleaner in general. The rest of the bathroom is already a maze of exposed copper, which I polished and actually looks great. Might as well do the tub in copper right up to the faucet.
Any compelling reason not to do this?
Strom plumbing/Sign of the Crab makes the ells that fit the faucet, but at $50 and a week+ wait, plus the lost time in getting a tenant in this place, it doesn't seem worth it to me.
Thanks.
wombosi is offline   Reply With Quote
Old 01-23-2009, 04:45 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,588
Ayuh,...
I did that at a waterfront rental,...Year rounder...
I sprayed them with Clear,+ it's holding up goin' on 3 years now...
If ya Don't, it'll tarnash,+ turn green/ brown in no time...
Btw,...
Adding those Unions you see there makes Repairs much Easier.....
Old 01-23-2009, 05:05 PM   #3
cool man, nice work.
is there any risk of damaging my supercoated brass faucet when sweating on the 90 to the female threaded adapter?
i wouldn't be able to sweat any additional pipe before because the rotation would hit the rim of the tub.
thanks.
Old 01-23-2009, 05:23 PM   #4
Sound like it will work fine, and nice work Bondo. There shouldn't be a problem with the soldering on the faucet, but just to be safe, I would rap a cool wet rag around the trim while soldering.
zosoplumber is offline   Reply With Quote
