Clawfoot Tub Faucet Diverter Not Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2012, 05:01 PM   #1
Clawfoot tub faucet diverter not working
My clawfoot tub faucet is in need of repair. The lever that controls the tub or shower option stopped working. It became very loose and I could not get water to come out at all. I can't find much info about this on the web. From what I can gather its a compression valve problem?? There appears to be a torn plastic washer. Can this brass fitting be removed and replaced? Help!
Jane586 is offline   Reply With Quote
Old 06-05-2012, 05:16 PM   #2
MarginallyQualified
Rewards Points: 2,464
what washer? what brass fitting? I can't see what you have.
Good thing everyone has a digital camera and you can attach pictures to your posts... huh? Do that and we'll try again... OK?
Old 06-05-2012, 07:33 PM   #3
That's odd because I did attach a photo and I can see it.
Old 06-05-2012, 08:04 PM   #4
MarginallyQualified
Can this brass fitting be removed?
Yes
and replaced?
Probably.
It appears that the brass fitting has threads in the center...
probably for a handle. Put that handle or a bolt in there and pull.
That should get it out.
Find a really good plumbing supply house.
Take the fitting and the picture there.
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
clawfoot tub woes continue - found possible solution wombosi Plumbing 3 01-23-2009 05:23 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
