#1 |
City water supply to meter in house
The house is 6 months old. I am finishing the basement and when screwing a 2x4 to the floor I went through the plastic water supply pipe. I am using 3" tapcons. Should the main water supply line be that shallow? Now my issue is I have to cut out and join the plastic pipe. Does anyone have suggestions as to which is the best way to do this, understanding that it will be buried under the basement floor. What do I use or need
#2 |
HVAC / Plumbing
depends on the type pipe that you have as to what to repair with.. It the break on your side of the meter or city side ?? If on city side .. Cut out the concrete & let them repair
#3 |
The floor should be at least 4" thick. Doubtful that the Water Department will fix a leak you caused, without charging you. Most times, the water line from the City tap to your home is your problem, even if it is before the meter. They usually consider any pipe from the curb stop at the property line, yours. With the home being only six months old, I would be contacting the builder. The City should also have inspected the concrete job.
If you have never made a mistake, you haven't done much. |
| Display Modes | |
| low hot water pressure | angus242 | Plumbing | 10 | 01-08-2009 12:41 PM |
| Basement water meter below floor level | redfox1 | Plumbing | 5 | 12-10-2008 09:20 PM |
| Low Hot Water Pressure | btennant | Plumbing | 4 | 12-09-2008 10:31 PM |
| HELP - Lost water pressure to shower after turning off water to house | jpw28 | Plumbing | 8 | 02-20-2008 09:07 PM |
| Private Water Meter? | fauer | Plumbing | 9 | 12-20-2007 07:44 PM |
