City Water/sewage & Very Heavy Rain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2010, 12:45 PM   #1
City water/sewage & very heavy rain
So we got a bad smell in a toilet. This has never happened before.
Can anyone step me through the reasoning connecting a heavy rain with this smell, if there is a connection?
Should I be looking for damage, tearing up drywall, testing for blockages?
Old 08-13-2010, 04:20 PM   #2
if the smell is coming from the toilet, I would look for mineral buildup. I wouldn't figure the heavy rain would effect your toilet, the city sewer plant maybe, depending on how your city sewer lines are hooked up. Now if your toilet over-flowed and no body told you, you might have lingering odors present.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 08-13-2010, 06:32 PM   #3
It might be your wax ring, it might be damaged and not hold a air tight seal and as a result sewer gas ( methane) is coming up and into your house, what does it smell like, is it only coming from your toilet, thats the first thing that comes to my mind, good luck. PS. are you sure its related to heavy rainfall or could it be just a coincidence.
also check your water tank, make sure its at the proper water mark (1 inch below the overflow tube.) your trap may not have enough water to competley have a correct seal.
Bigd3129 is offline   Reply With Quote
Old 08-13-2010, 06:35 PM   #4
Rewards Points: 50
Where in your home is the offending toilet located,basement?Do you have weeping tile or downspouts connected to the city sewer?
daveb1 is offline   Reply With Quote
Old 08-13-2010, 08:50 PM   #5
Upstairs, and no.
Hashing this over with you guys makes me think: drain lines slope downward so if sewer gas is lighter than air it would go back to the house.
If there is 4" of water in a trap it takes only 0.1 PSI to overcome this.
With heavy rain and storm conditions I suppose there could be pressure differences in the sewer gases that occasionally overcome the water in traps.
"if the air pressure within the drain becomes suddenly higher than ambient, this positive transient could cause waste water to be pushed into the fixture, breaking the trap seal, with dire hygiene and health consequences if too forceful. "
Old 08-14-2010, 11:08 AM   #6
Rewards Points: 1,548
Does the smell go away after the storm ends?
Is the water level in the toilet bowl unusually low compared with other toilets?
Do you see the water in the toilet bowl vibrate when the wind blows?
You could have had a long term leak under the toilet bowl.
Old 08-14-2010, 11:24 AM   #7
...It came and went during the storm.
...No.
...This we will have to watch for.
...No stains visible but I guess the waste water could follow the pipes down.
I need to go on the roof anyway to repair gutter damage so I'm going to check the vent pipe for that bathroom.
Old 12-02-2010, 01:44 AM   #8
Rewards Points: 978
hey man-did you find out what was causing it?
federer is offline   Reply With Quote
Clean water coming up after heavy rain, not sewer water Nancy J Plumbing 2 06-07-2010 08:52 AM
Rain Gardens Colchicine Green Home Improvement 2 02-13-2009 06:35 AM
Exactly what is my City inspector DO when he inspects a replaced hot water tank? 73andsane General DIY Discussions 5 09-05-2008 07:46 AM
Will heavy rain within the first 24hrs destroy my freshly seeded lawn? joeyboy Landscaping & Lawn Care 2 08-02-2007 06:07 PM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 12:45 PM
