Circulation Pump Suggestion - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2011, 11:07 PM   #1
Rewards Points: 39
Hi folks,
In an earlier posting, I described a situation where I have a solar water tank on the roof. I used the approach of connecting the solar tank with a holding tank in the basement before distributing to the rest of the house. Valves are used to allow solar tank water to feed the holding tank.
I'd like to circulate the water between the solar and holding tank during the day to keep the holding tank with hot water as the solar collectors picks up the sun's heat. Can you recommend a "simple" circulation pump that can move water 33 ft between the 2 tanks because the solar tank is not pressurized.
Preferrably the pump can run off a small solar panel so circulation occurs when the sun is out.
Thanks,
atw58 is offline   Reply With Quote
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 11:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Do I need seperate vent stacks for basement pump and basement sink? twinfins Plumbing 5 12-08-2010 12:28 AM
Help Needed ... turn on circulation pump when furnace in AC mode? Diranged HVAC 12 06-04-2009 07:33 AM
