Circ Pump Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2014, 05:59 PM   #1
Circ pump questions
So the gravity fed hot water circ loop I installed in our new house is not working well enough, so I have to suck it up and install a circ pump.
Do any of you guys have one you use/recommend. Single story ranch house. 2.5 bath. 1700 sq feet. I am looking for something reliable, not cheap. and low GPM. The closest supplyhouse has a little Grundfos. I am not interested in the one from Home Depot, a watts maybe? I also saw one on the interweb made by "Laing". Said it was low flow and pretty energy efficient, so I probably would not install a timer. What do you seasoned plumbing professionals recommend?
Also, when I was looking on the internet (and even at a supplyhouse this week), people keep mentioning "head pressure". If it is a loop, is there any head pressure? Maybe an engineer can explain that to me.
broox is offline   Reply With Quote
Old 03-25-2014, 07:09 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 662
I like Laing. Repair is a simple cartridge replacement.
Don't forget check valves and a way to purge air so it doesn't air lock.
I replaced a Grundfos last week- It said Watts on it too. It was the retro fit style that converts your CW line to the HW return. It was only 3 years old....
The Following User Says Thank You to TheEplumber For This Useful Post:
broox (03-25-2014)
Old 03-25-2014, 08:42 PM   #3
Lightfoot's Avatar
Rewards Points: 272
i used to own a motel and it had a Bell & Gossett brand circulating pump, 1/4 hp. Was super quiet and the only thing i ever had to do to it was replace the rubber motor mounts and coupling. Only did that twice in 19 years. A few drops of oil in the tubes every few months and it was pretty much trouble free. It's the only one i ever had dealings with, so i can't comment on other brands.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 03-25-2014, 08:53 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Its one in the same Home depot, watts grundfos
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-25-2014, 08:59 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Best way to go Bell and gossett
Old 03-25-2014, 09:00 PM   #6
Plumber
Rewards Points: 662
Thats the one. It went bad in 3 years- not saying that is typical though
Old 03-26-2014, 04:06 AM   #7
An old Tradesmen
Rewards Points: 7,268
Head pressure in this case is the resistance to flow in your piping system/loop.
1/2" copper has a head pressure loss of .35' at .5GPM per 100' of length. All fittings(ells, tees, valves, etc) have an equivalent length in feet, that can make a seemingly short run, equal to 250 foot of straight pipe.
The Following User Says Thank You to beenthere For This Useful Post:
broox (03-26-2014)
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
How to size circ pump secutanudu HVAC 4 12-30-2010 04:27 PM
Circ Pump? Water heater? Boiler? diamondjoe Plumbing 1 12-25-2010 08:20 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 08:47 PM
