Chronic Sewer Gas Odor Emitting From Upstairs Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2011, 08:37 PM   #1
Chronic sewer gas odor emitting from upstairs bath
I bought my house (a vacant forclosure) and soon after moving in, noticed a strong septic odor in the upstairs ("ground level"). At first I thought it was because I live caddy-corner to the town's main sewage lift station, but I soon noticed the odor emitting from my bathroom. The bathroom upstairs is directly on top of the bathroom downstairs (in the basement). The problem was so bad and random it would wake us up in the middle of the night. The odor is terrible. About the only thing that occasionally alleviates a "flare up" is to run water into the tub. This does not always work. I hired a plumber from a reputable company and he came out on my day off and looked at the upstairs bathroom. He felt that I needed to have a mechanical trap installed in that bathroom and so he put one in under the sink, even though the odor seemed to emitting from the tub. He felt that this would stop suction which was sucking the water from the P-trap. This worked, or so it seemed, for a couple of weeks. Now the problem is bad as ever. It's very embarrassing when company is over.
Since I demolished the downstairs bathroom due to water damage, I now have direct access to the main sewer pipe from upstairs down to the floor of the basement. I never detected odors in the basement, just upstairs. However, I'm wondering if something down here is causing it. P-traps seem to be in all the right places and I'm scratching my head here.
kadetklapp is offline   Reply With Quote
Old 05-04-2011, 09:06 PM   #2
Rewards Points: 276
Roto Rooter? But seriously, post some pictures especially of the exposed plumbing under the tub. There are plenty of folks on here that can help you. I don't know why the plumber thought it was the sink trap if the smell was coming from the tub. Sounds more like the tub trap is having water siphoned out to me.
Jim F is offline   Reply With Quote
Old 05-04-2011, 09:55 PM   #3
DIY staff
Rewards Points: 7,174
Sounds like a venting problem----How old is the house?
What are the drain pipes made of?
Can you put a hose into the roof vent and flush it out?
We need a few more details---Could be several things.---Mike----
Old 05-05-2011, 07:02 AM   #4
Ok here is a picture of the drain under the upstairs tub.
The house was built in 1978. I know next to nothing about plumbing so you'll have to bear with me.
Whenever the toilet is flushed, a very audible "gurgling" is heard in both tub and sink drains.
I think the only vent is attached to the side of the house. I do not know what would happen if I tried to flush it out so I never touched it.
Old 05-05-2011, 07:16 AM   #5
well that definitely appears to be unvented, or at least an s trap. i've a bit concerned with the sound while the toilet flushes. you might have a drain stoppage as well. do you hear the same sound when the washing machine drains? you should probably bring in an actual "reputable" plumber (not a franchise rooter co., talk to your neighbors and find someone they've used and been happy with) and show him what you have exposed. listen to what he says, get a detailed written bid, and then get 2 more afterwards. be prepared to redo the upstairs bath when the basement one is done, it could get pretty extensive
the_man is offline   Reply With Quote
Old 05-05-2011, 07:26 AM   #6
Plumb or Die!
Firstly, that S-Trap under the tub is probably siphoning itself dry.That needs to be fixed for sure. I'd like to know how the bathroom is vented. Bet it's wet vented and also done wrong.
plumber666 is offline   Reply With Quote
Old 05-05-2011, 12:18 PM   #7
I hear the sound when the washing machine does drain. I don't hear it when I flushed the downstairs toilet.
I called a plumber and he is supposed to swing by tomorrow to check it out. He's owned a large plumbing company in my town for more than 35 years so hopefully he can pin-point the problem.
Old 05-05-2011, 07:12 PM   #8
DIY staff
You made a good call---to an experienced plumber!
You made his job easier ,having a good view from below.
Please let us know the outcome.---Mike--
Old 04-03-2012, 03:52 PM   #9
No outcome as of yet. I'm in the process of rebuilding the downstairs bathroom as we speak. It's about 40% complete. I feel that in order to actually fix this problem I will be forced to tear out the upstairs bath, so I'm going to go ahead and get a working bathroom at ground zero and work up. Can a vent simply be attached to the highest point of the main sewer line (from upstairs drain down) and go up thru the walls and out thru the roof?
Old 04-03-2012, 05:05 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
I would not install the ceiling in the downstairs bath until the plumbing for the upstairs bath is corrected. Was that CPVC valve hidden in the ceiling?
All that plumbing looks hack and should be replaced.
Coastal South Carolina
Old 05-05-2016, 04:59 PM   #11
Rewards Points: 4
Re: Chronic sewer gas odor emitting from upstairs bath
I have a basement bathroom directly under an upstairs bathroom. When the upstairs bathroom is used for the #2 business it gives off an awfully strong odor downstairs, and spreads into the recreation room that's attached. What do you think the issue could be. Been dealing with this for some time now and it's very embarrassing when company is over.
Fiyacheef is offline   Reply With Quote
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
New sewer pipe for new bath in detached garage gante Plumbing 1 04-10-2011 06:14 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath Heikks2002 Plumbing 3 01-15-2010 10:21 AM
Hooking New Bath into Sewer Pipe jasoncw Plumbing 4 03-04-2008 04:42 PM
