Chrome P-Trap To ABS Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2013, 03:35 PM   #1
Chrome P-Trap to ABS Drain
I'm redoing my en-suite bathroom and want to change the previous abs p trap to a nice shiney new chrome p trap like this:
http://www.homedepot.ca/product/p-tr...-chrome/840272
I figured I'd need to use something like this:
http://www.homedepot.ca/product/abs-...ub-x-sj/959890
combined with this:
http://www.homedepot.ca/product/abs-...ag-prpk/966989
to get the drain from the sink to the vertical abs in the wall. Unfortunately there isn't enough room in a 2x4 wall for the combination of the two fittings. My goal is to get it to look good, similar to :
with no ABS showing at all. How do I achieve this in the most aesthetically pleasing way possible? The entire wall is open (no drywall) so I can go happy hardcore on any changes necessary.
iamthemoose is offline   Reply With Quote
Old 09-22-2013, 03:55 PM   #2
DIY staff
Rewards Points: 7,174
You will want to set the 1 1/4" trap adapter so the threads start at the finished wall surface----this will allow you to tighten the nut that holds the P-trap.
You will need a chrome escutcheon that will cover the nut--there are several styles available---
Old 09-22-2013, 09:43 PM   #3
Rewards Points: 1,770
If your that far off where you need a 90 your going to have to redo where the plumbing comes out of the wall prior to setting the vanity.
Old 09-23-2013, 09:39 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
I didn't look at all your links at first- just thought you wanted to cover the trap adpt.
A solution is to offset the vertical waste and vent with 45's so it centers on your trap
how do i repair a broken drain trap echobravo Plumbing 9 02-04-2012 06:50 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 01:40 PM
should I replace the drain and P trap jameshow Plumbing 2 04-26-2009 10:32 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
