-   -   Chrome P-Trap to ABS Drain (http://www.diychatroom.com/f7/chrome-p-trap-abs-drain-187434/)
iamthemoose 09-22-2013 02:35 PM
I'm redoing my en-suite bathroom and want to change the previous abs p trap to a nice shiney new chrome p trap like this:
http://www.homedepot.ca/product/p-tr...-chrome/840272
I figured I'd need to use something like this:
http://www.homedepot.ca/product/abs-...ub-x-sj/959890
combined with this:
http://www.homedepot.ca/product/abs-...ag-prpk/966989
to get the drain from the sink to the vertical abs in the wall. Unfortunately there isn't enough room in a 2x4 wall for the combination of the two fittings. My goal is to get it to look good, similar to : http://homeguides.sfgate.com/DM-Resi...0&keep_ratio=1
with no ABS showing at all. How do I achieve this in the most aesthetically pleasing way possible? The entire wall is open (no drywall) so I can go happy hardcore on any changes necessary.
oh'mike 09-22-2013 02:55 PM
You will want to set the 1 1/4" trap adapter so the threads start at the finished wall surface----this will allow you to tighten the nut that holds the P-trap.
You will need a chrome escutcheon that will cover the nut--there are several styles available---
Ghostmaker 09-22-2013 08:43 PM
If your that far off where you need a 90 your going to have to redo where the plumbing comes out of the wall prior to setting the vanity.
TheEplumber 09-23-2013 08:39 AM
199 Attachment(s)
I didn't look at all your links at first- just thought you wanted to cover the trap adpt.
A solution is to offset the vertical waste and vent with 45's so it centers on your trap
