Chlorinating A 2" Water Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2010, 04:27 PM   #1
Rewards Points: 16
Chlorinating a 2" water well
I just had my 2" water well reworked with a new above ground pump and motor as well as new jets and leather seal in the bottom of the well. The casing is 2" with a smaller pipe run inside the 2" casing that has the jet and leather seal attached to the end. This is the old style well before the current 4" well became the standard. Since it was reworked I now have a coliform problem and need to chlorinate the well but can only find how to do a 4" well. There is nothing on the internet that I can find that explains how to treat one of these old 2" types. I just spent $1200 dollars getting it reworked and can't use it. Does anyone know how to treat one of these old 2" wells? The well is 90' deep, water level @ 43' and output is 8GPM.
Any help would be great.
charlie58 is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
