Old 11-02-2009, 10:32 PM   #1
Send a message via Yahoo to fburke
Default Chimney / Vent shaft
Massachusetts
I have a chimney in my house; my house is old it was built in the early 1900's. The clean out door at the bottom of the chimney in an unfinished basement is rotted off.
My question is where this chimney is not used for any type of fire place. Just as a vent shaft for a gas water heater and a gas heating system. Is a clean out door required? Or can I seal this opening up with bricks.
fburke is offline   Reply With Quote
Old 11-03-2009, 06:33 AM   #2
The flue still needs to be cleaned. The brush used will free the soot loose so it can be removed from the cleanout door. So yes it is needed.
Bob Mariani is online now   Reply With Quote
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Put the shaft of a table lamp together before attaching it. Learn how to put the wood together to make a table lamp shaft in this free video on home decor and lighting. Read More »
Hi! This is John on behalf of Expert Village. Now what I am going to do is show you another aspect of what you need to do is get ready for the firewood season. Here I am on top of my roof of my home and what I will do I will be taking off the cap here on... Read More »
gas hot water tank vent & chimney flue trees HVAC 11 10-16-2009 11:23 AM
Roof Leak Around Chimney robertr4836 Roofing 3 03-11-2008 01:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 05:12 PM
hot water heater venting into chimney problem dvarga HVAC 0 10-30-2005 10:45 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
