Originally Posted by Beepster
Maybe take a picture of your situation.
I think to what you are referring is only used on kitchen islands and similar areas where there is absolutely no other way to vertically vent.
I will let pros pipe in on this.
B
Thanks... Thats exactly what i have been thinking about - I have not seen this used/referenced for anything other than a kitchen island installation.
I did a quick "rough" floorplan layout of what the attic will look like - maybe this helps.... the black dot marks the spot of the current vent location.
what about going up above the door frame then dropping to the horizontal vent run for the sink?- would that work?
I have read both yes and no to that - the yes version says as long as the vent is 6" above the highest fixture served by the runs - it will be ok.
