Checking For Vent Stack Obstruction... - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2010, 12:47 PM   #16
Homerepairguy's Avatar
Rewards Points: 998
Originally Posted by Michael Thomas View Post
The potential problem with plumbing vent screens in cold climates is that they can provides a matrix for ice formation. I don't have a picture of an ice-occluded screen, but here's an example of how these pipes ice up even without a screen: Plumbing Vents are Subject To Frost Closure In Cold Climates - Paragon Inspections Chicago
Good point. I live in an area that never freezes so never experienced or thought about that problem. --- In areas where frost can be a problem, I would install two small diameter stainless steel bolts in the form of a cross at the vent top. Anything small enough to fit hopefully would not clog the vent and should be flush-able using a garden hose.
Thanks,
HRG
Homerepairguy is offline   Reply With Quote
Old 05-15-2012, 12:01 PM   #17
Covering Vents In Freezing Climates
FWIW; Due to leaves and other debris we covered our vents & Chimmey cap with a wire screen-much like chicken coop wire. Then a very frigid winter came upon us and the condensation combined with the zero /subzero weather made for a build up of ice on chimney vent screen. Thankfully the heating system's (new boiler) safety mechanism turned the boiler off once it sensed the lack of venting or CO2.
That was the end of screening on any vents.
dogwoman is offline   Reply With Quote
retaining wall around chimney stack Master Brian Building & Construction 0 08-25-2010 03:27 PM
vent stack leak GeorgeE Plumbing 1 04-18-2010 03:26 PM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 10:13 AM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
