Checking Thermostat And Heating Element. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2009, 10:03 PM   #1
Blank
Not sure how to erase post.....found my answer
Ineedhelp2009 is offline   Reply With Quote
Old 02-22-2009, 07:16 PM   #2
Maybe I didn't. I have 2- 50 gallon water heaters. When checking everything seems to be working. All of the elements are good. When checking voltage on the heating element should i get 240 at all times or only when it kicks on? Will both thermostats run at the same time?
Here is the website i used.
http://www.ehow.com/how_2179106_elec...step-step.html
See step 5 at the bottom i only get 240 when the top thermo is off and the bottom kicks on.....The two screws on heating element also only read 240 when that one is on. I checked continuity on everything.. what am i doing wrong?
I do have body sprayers 5 run at the same time, but 2 months ago my water would last 35 mins easy. I have all four thermostats at 125 should i do the top hotter or should i turn all four up. Both water heaters do the same thing. When i turn the temp up i can hear them kick on.....(all four)
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 04:39 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
