Checking To See If There Is Moisture Around A Shower? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2010, 10:45 PM   #1
Rewards Points: 682
Checking to see if there is moisture around a shower?
I've used a moisture detector on the walls around a shower, and can't find any signficant moisture. Is this enough to show there is no leak problem? Or do I have to cut holes in the walls?
darsunt is offline   Reply With Quote
Old 06-21-2010, 11:01 PM   #2
Owner
LateralConcepts's Avatar
What leads you to believe there's a leak in the first place?
LateralConcepts is offline   Reply With Quote
Old 06-22-2010, 08:29 PM   #3
Rewards Points: 682
We had someone living in that room who complained about a musty smell. But she never opened the windows so I don't know if I believe her.
All the drywall I tested around the shower and bathroom are dry, so I don't know if I would be wasting my time cutting into the walls.
Old 06-23-2010, 06:50 AM   #4
DIY staff
Rewards Points: 7,174
Musty smell? Could have been dirty towels left to dry---If your tests showed nothing--I'd just give the place a good scrubbing and then repaint.
----Mike----
Old 06-23-2010, 09:12 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you live in the city and have a meter at the street, you can check for a water leak in the wall by turning off all the valves in the house, and watching the meter to see if it is moving.
Usually you would SEE signs of leaking through the drywall though.
Journeyman Plumber
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 09:29 AM
