Checking For Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2011, 06:04 AM   #1
Checking for leaks
I am finishing up re-plumbing my whole house and was looking for the right method to check for leaks. I have been told to try a two different methods.
First was to just turn on the water and inspect for leaks.
Second was to install a pressure gauge and fill the lines full of air, and let it sit over night and see if it holds the air pressure.
Right now there is obviously no water in the lines since there is new pipe from the main all the way through the house. Also I used copper if it makes a difference.
Thanks,
gseith is offline   Reply With Quote
Old 06-20-2011, 06:28 AM   #2
The second method is much less messy in the event there is a leak. And the leak is more easily repaired if there has never been water in the system.
Old 06-20-2011, 06:29 AM   #3
Stay-at-home GC
Turn it on and listen works pretty good.
Turn off the HW tank and toilet supplies and then turn on the main supply.
After the Cold system is charged walk through the house and listen. After the cold lines are charged turn on the HW.
Walk through again and listen. Turn on the toilets.
Mark on the meter or note the smallest digit. Come back in an hour and check
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 06-20-2011, 06:30 AM   #4
But will the leak be easy to find if there is no water coming out? I would expect it to make some noise. Also how much pressure should I use?
Old 06-20-2011, 10:03 AM   #5
Test with air @ 1.5X the working pressure, or what the water pressure will be. Testing with water is alright but if the joints only drip, it will be difficult to find until water stains are visible, not all joints spray water when they leak. Leave air on for 1 hour and gauge should not drop at all.
Dougtheplumber is offline   Reply With Quote
Old 06-20-2011, 10:07 AM   #6
Should have it finished this week and will give the air a try.
Thanks,
Old 06-20-2011, 10:30 AM   #7
spray joints with soapy water and check for air bubbles
The older I get the better I was
Old 06-20-2011, 11:17 AM   #8
Rewards Points: 320
I tested with water and found a few leaks, which isn't hard if the place is gutted. However, I'd probably recommend doing an air test. As people have said, it's not as messy or a pain if you need to make repairs and also, if you use water, you can only test at your water pressure. Using air will allow for a more thorough test which would also be good in the event you ever add something to increase your water pressure or if the city makes upgrades which increases your pressure.
autx790 is offline   Reply With Quote
Old 06-28-2011, 09:14 AM   #9
Well i followed through with the air test and I would recommend it. I only found three leaks which I didn't think was bad considering this was my first time plumbing a whole house from scratch.
The first two I could hear and the third I found by spraying soapy water on the connections.
Thanks for the advice.
Checking to see if my calculations are right kossuth Electrical 9 03-20-2011 11:39 PM
Checking an Install KStreetQB HVAC 1 03-14-2011 04:15 AM
checking for rafter damage joefromcal Roofing/Siding 9 10-02-2010 12:22 PM
Checking circuit load for recessed lighting Nathan0115 Electrical 12 05-07-2010 03:49 PM
Checking Subfloor for Flatness markospencer Flooring 7 10-01-2008 05:03 AM
