Check Valve For Main Sewer - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2012, 07:18 PM   #1
Rewards Points: 252
Check valve for main sewer
After getting 3' of sea water, sea weed, and sand in my basement from my toilet, I'm thinking of putting a check valve on my sewer main when I renovate. Anything I should look for? Are they effective? Should I install an actual shut off valve as an emergency measure just in case?
Thank you
mazzonetv is offline   Reply With Quote
Old 11-03-2012, 07:10 PM   #2
Rewards Points: 252
Just bumping this. Anyone??
Old 11-03-2012, 07:47 PM   #3
Rewards Points: 3,528
Thank you
Check valves work,and you have to be home to activate a shutoff valve.
Canarywood1 is offline   Reply With Quote
Old 11-03-2012, 08:05 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 564
This is the one I install - at any depth.
http://www.rectorseal.com/Clean-Chec...ter-Valves.php
Old 11-03-2012, 08:12 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
That's ridiculous. Back-flow preventers are automatic
Coastal South Carolina
Old 11-03-2012, 08:33 PM   #6
And who said they were not???
Old 11-03-2012, 08:41 PM   #7
A "Handy Husband"
rjniles's Avatar
You did.
"you have to be home to activate a shutoff valve"
Old 11-03-2012, 08:45 PM   #8
Plumber
Rewards Points: 564
I've also put this one in- pretty pricey though.
http://www.jrsmith.com/assets/docume...re/spm0216.pdf
It went into a basement of a medical building after being flooded twice. We wired the flood guard alarm to the receptionists desk so she would know if it activated- works off negative pressure.
This thing would probably take your finger off when it falls shut!
Old 11-03-2012, 08:55 PM   #9
You did.
As far as i know all back flow preventers are automatic,and a shut off valve has to be manually turned off,i guess you don't know the difference between the two.
Old 11-03-2012, 09:16 PM   #10
A "Handy Husband"
rjniles's Avatar
Sorry, I misread your post and thought you said you had to be home to turn off a backflow preventer.
Old 11-04-2012, 06:10 AM   #11
Rewards Points: 252
Thank you - I will look into it. I can only see the sewer plug in my sewer trap, so I guess that means an lot of jack hammering in my future to access the main.
Thank you all
Matt
Old 11-04-2012, 06:31 AM   #12
Build a room with plastic that you are going to work in and cut the concert with a circular saw.
Only cut a quarter inch deep at a time and keep going over the same cuts till your through.
At the corners dill holes.
Depending on how much your cutting out cut it down to smaller chunks.
The first chunk will be hard to get out but the rest will lift out with some thinking and planning.
Last month I cut 3 16 by 16 squares and 45' of 9 wide for a trench. I had to replace all the cast under the house. I did all the cutting and moving the concrete in about 40 hours. Getting it all up the stairs was done a week later by day laborers.
1950home is offline   Reply With Quote
Old 11-04-2012, 07:23 AM   #13
Rewards Points: 1,500
Check valves are not foolproof. Solid material in the waste water outflow from the house can hold the valve ajar and sewage can then back up although more slowly.
Husky/CH Compressor check valve question EdPDX Tools 7 10-02-2012 04:37 PM
Check Valve Choices for Sump Pumps jpepe3691 Plumbing 0 02-13-2012 01:37 AM
Check valve positioning - is this incorrect and could it cause a cross connection? kissiffer4 Plumbing 42 03-29-2011 11:13 AM
Deep well water tank check valve clunk tullhead Plumbing 0 06-22-2010 09:16 PM
