Check Valve Keeps Coming Off! - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2014, 08:33 AM   #1
Rewards Points: 892
Check valve keeps coming off!
Take a look at the pic provided.
Typical sewage ejector setup in my basement for our full bath. Works great other than the INCREDIBLE water hammer force. I understand it's normal and have been dealing with it for a year now since I bought the house.
My problem is that the hammer is so strong, it physically pulling away from the rubber boot above it. Once a month, I detect the boot has slipped away causing fluid to spray out onto the walls!
I'm sick of it. No matter how hard I crank down the screws on the boot, the hammer pulls the boot off. Did I install something wrong?
The system was already there when I bought the house. I replaced the ball valve, check valve, boots and pump.
I added some wood blocking (not pictured) between the wall and the pipes to secure the pipes better and to cut down on the water hammer valve movement. It worked but the boot is still coming off. Thoughts?
Daugela is offline   Reply With Quote
Old 01-24-2014, 11:11 AM   #2
Rewards Points: 286
Looks right. If you installed it backwards, you would diffinately know it. nothing would be going out and everything would be backing up.
Check valves can be quite noisey. Not saying that's your problem. They do sell higher end ones that are silent which are spring loaded to prevent that severe hammer. Sorry I couldn't be of more help to you. Others will be along with more advice.
jmon is offline   Reply With Quote
Old 01-24-2014, 11:14 AM   #3
Rewards Points: 892
It works fine, but the hammer is actually destroying the set up. I can deal with the noise, but I'm convinced the hammer is pulling it apart.
Soooo……I bought a silent valve today off the internet.
Old 01-24-2014, 11:20 AM   #4
Rewards Points: 286
Great. let us know if it's any better for ya. I installed one for my sister-in-law and she told me it made a huge difference.
Old 01-24-2014, 12:14 PM   #5
Rewards Points: 892
I was hesitant at first. Everyone told me when I bought my regular valve that the silent ones are a gimmick. But after reading the reviews online, there's no truth to that. MANY said they are incredible and worth the money.
Will post a review.
The Following User Says Thank You to Daugela For This Useful Post:
jmon (01-24-2014)
Check valve for tub drain? roasted Plumbing 19 01-01-2013 09:15 AM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Leaking double check valve assembly (Watts) secutanudu Plumbing 0 06-07-2009 06:52 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
check valve question burr HVAC 3 11-30-2008 10:03 AM
