Old 06-23-2009, 11:28 PM   #1
(check valve) do I need ??
Putting in water system in pole barn i am using 55 gallon(plastic) drums for water sorce,will tie 4 drums in with 3/4 copper line after line is run between the 4 drums will be going into a shallow well pump to create the preasure for the system then to a hot water tank do i need to install a check valve any were in this system the shallow well pump is a small 5 gallon pump you can adjust preasure from 40 up to 70 pounds and please if anyone has any more input would greatly be a big help
mark g is offline   Reply With Quote
Old 06-24-2009, 12:46 PM   #2
Water quality'n pump guy
You need a check valve in the line to the pump from the barrels. Otherwise when the pump is off the pressure tank will push the water back through the pump, into the barrels and when the pressure falls to the cut in setting of the pressure switch, the pump will run to the cut out setting and this will repeat forever or at least until the pump dies. If you had one tank you'd use a jet pump foot valve on the inlet pipe's end in the tank.
Gary Slusser is offline   Reply With Quote
More On This Topic
Hi! My name is Marc representing expertvillage.com. This clip is going to demonstrate the professional installation of a 180 gallon saltwater aquarium for your home or your office. The filtration for this system is rather sophisticated, consist of a wet... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
If you find yourself in a situation without the right pump for a presta valve you'll need to use an adapter. Using the adapter adds a couple of steps, mainly putting it on and taking it off. You start off by opening the presta valve as you would normally... Read More »
If you like putting things together with your hands, a career as a plumber might be for you. Plumbing is a highly skilled profession and one that will always be in demand. Plumbers install, maintain and repair the systems that keep our water flowing... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
HOW TO diagnose gas valve problems Nestor_Kelebay How To Guides 5 03-07-2010 03:35 PM
Leaking double check valve assembly (Watts) secutanudu Plumbing 0 06-07-2009 07:52 AM
Check valve and foot valve on same well feed? rtoni Plumbing 4 06-04-2009 10:42 AM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 08:42 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
