Check Valve For Column Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2011, 08:12 PM   #1
Check valve for column sump pump
About to replace my submersible sump with a column sump pump. Just wondering where i should place the check valve for column sump pump? Ok to have it screwed directly into the sump outlet, or have it up a few feet in the discharge pipe?
fjacky is offline   Reply With Quote
Old 12-01-2011, 08:42 PM   #2
Rewards Points: 12,808
I never use a screw in ones I use the ones that just slip over PVC pipe and have a hose clamp on them. That way I can disconnect it and remove the pump if needed.
It can be any place past the outlet for the pump.
Old 03-13-2012, 05:40 PM   #3
I just installed a 1/3 horse column pump and after it runs I get the dreaded loud clunking sound.
Right now I have the screw in check valve screwed directly into the pump..should I place the check valve higher up? I have vertical pipe going approximately 10 feet, then out the wall.
Should I put it at the highest point I can reach? (so I can replace easily if need be)
Old 03-13-2012, 07:57 PM   #4
The noise you hear may be the start up and stopping torque of the pipe itself.
How is the pump secured?
Old 03-13-2012, 09:15 PM   #5
Pump is sitting in pit, connected with abs pipe. If i went to the bendy soft pipe, would that help?
Old 03-13-2012, 09:33 PM   #6
It didnt make the clunking sound when the submersible pump was in.. Only when i swaped thst out with pedestal pump.
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
Help with check valve on recirculating pump joeq Plumbing 21 10-08-2011 05:24 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 02:17 PM
Loud sump check valve BlueBSH Plumbing 1 01-19-2010 05:14 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
