Check (foot) Valve Or Clog? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2013, 07:39 PM   #1
Check (foot) valve or clog?
Anyone know if I have a check valve in this set up??
I've got a drilled well, everything is 20yrs old and I don't have water... I could hear water draining out of my house and can't get the lines to prime. I manually flip the switch to prime the line but only a 1 second spurt of pressure.
Recently there has been a lot of sediment in the filter. I have needed to change the filter (20 particulate) 3 times in 12 days. Is it possible I have a clog??
Any help would be great as I've got 3 kids, a wife and no water
Check (foot) valve or clog?-image-2685934758.jpg   Check (foot) valve or clog?-image-4269919274.jpg   Check (foot) valve or clog?-image-3700257285.jpg
Fantastic is offline   Reply With Quote
Old 01-30-2013, 10:56 PM   #2
Roofmaster
Rewards Points: 2,172
First of all, I would suggest that you change out all that old incredibly corroded Galvanized pipe. Your pressure switch nipple is probably clogged solid. Ohm out your pump, also. Sounds like your pump is history, and the strainer is gone. I dont like the amount of sediment though. How deep is your well?
Old 01-30-2013, 11:14 PM   #3
Rewards Points: 13,300
May just lift the pump some in the well.
Old 01-31-2013, 12:06 AM   #4
You mean corrosion on pipe is bad?!? LOL Moved in here September and still looking through some things to plan out a budget for needs wants and has to...
The well is a 6" in diameter drilled to 10.81 meters (35.4ft) with a submersible pump on a pitless adapter(no idea what pitless adapter is) And the flow rate was calculated to 3.90 GPM
Old 01-31-2013, 12:11 AM   #5
Any form of steel pipe is bad. I'm suprized as bad as that looks it's not leaking.
That also sure looks like 1/2 copper coming in and out of that filter for a main run.
Should have been 3/4" for better flow.
Old 01-31-2013, 12:23 AM   #6
It must just be the pic.... The copper is 3/4... I'm lucky as the builder (who built this place and raised his family here) ran the 2nd and 3rd floor with 3/4 and the main with 1/2. I'm the 2nd owner of this house and I know this is just the beginning of repairs... Just hope they are far a part and not all at once!!
Old 02-01-2013, 12:00 AM   #7
Turns out my pump was buried in sand and almost didn't come up out of the well. Once out it was crammed full and it was a cheap one.... New pump and shortened the pipe (5') we are back in business.
Will be cleaning the well in the spring to get all the sand out.
Turns out my well steel pipe is 20' down then it hits bedrock. Then it's down another 10'. House has been here 20 yrs the well could be longer and no doubt has never been cleaned.
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 11:42 PM
Check valve for tub drain? roasted Plumbing 19 01-01-2013 10:15 AM
Husky/CH Compressor check valve question EdPDX Tools 7 10-02-2012 05:37 PM
sewage ejector pump check valve ogbill Plumbing 3 04-17-2012 12:28 PM
Check valve positioning - is this incorrect and could it cause a cross connection? kissiffer4 Plumbing 42 03-29-2011 12:13 PM
