Cheapest Way To Get 4in PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2011, 08:00 PM   #1
Rewards Points: 264
Cheapest way to get 4in PVC pipe
I am trying to build a hydroponic system out of 4in PVC pipe. Is there any kind of pipe I could buy that would be cheaper than normal drain pipe?
I've heard they make thinner PVC, but I can't seem to find it. $15 doesn't sound like much, but when you are talking about buying 50 pieces, thats damn near $800.
tibberous is offline   Reply With Quote
Old 11-15-2011, 08:05 PM   #2
Rewards Points: 582
the proper name you are looking for is 4" sewer and drain....lowes.home depot alot of hardware stores.... I think that is cheapest....ben
Old 11-15-2011, 08:15 PM   #3
Rewards Points: 264
You're not talking about this are you?
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
I thought about using corrugated tubing, would be a lot cheaper and save money in fittings, but it would take a lot more support and seemed like it might leak.
Old 11-15-2011, 08:23 PM   #4
Rewards Points: 582
sorry about this post...I deal strictly with plumbing supply houses not knowing lowes. homedepot and others would have same ...I do think it the same thing but would want to be sure ....you could ask if its equal to sewer and drain....from pics looks like it is....is that 8.63 per 10 foot....ben.....sewer and drain is white solid pipe in and out...
Old 11-15-2011, 09:02 PM   #5
Rewards Points: 264
Thanks. I think I might try a plumbing supply house tomorrow, or 84 lumber.
Sucks because you don't really getting a break by buying in bulk. If HD makes $2 selling a $5 fitting, that's not really bad, but when you need 40 fittings, that's $80 they make, profit, just on one item.
Old 11-16-2011, 08:06 AM   #6
Plumb or Die!
Just think about all the money you'll make from your hydroponic garden. What's a few grand on pipe and fittings?
plumber666 is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Well pipe access shutdown HomerRepair Plumbing 6 03-08-2011 09:22 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
