Changing A Well Pump Pressure Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2013, 12:12 PM   #1
Changing a well pump pressure switch
I'm suppose to change out a pressure switch tommorrow and the person that I'm going to do it for said the new pressure switch has more psi rating than his old one. Is there anything I need to readjust on the new pressure switch? I'm thinking I will probably have to adjust the cut in and cut out pressure on it. Thanks for the help..
sparkync is offline   Reply With Quote
Old 01-11-2013, 12:50 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... Generally speakin', they come in 30/ 50 psi, or 40/ 60 psi...
I wouldn't worry 'bout it, at All...
Bondo is online now   Reply With Quote
Old 01-11-2013, 02:07 PM   #3
Rewards Points: 29
You will need to adjust the psi in the bladder tank to 2 psi below the cut in on the new switch.
cube17576 is offline   Reply With Quote
Old 01-11-2013, 02:39 PM   #4
Rewards Points: 13,724
Or just get the right switch.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Some water pressure issues. Pressure switch and/or sediment filter. mgh-pa Plumbing 2 12-13-2012 09:28 PM
pressure switch adjustment for well pump Daneel Plumbing 4 06-09-2011 09:25 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
