Changing Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 11:09 AM   #1
changing water heaters
I live in a mobile home and the water lines are "plastic". The 3/4" water lines have a compressed fitting to connect the water lines to the flex copper lines going to the water heater. As you can see, the water connections on the tank (40 gal) are on the sides of the tank, one at the top area of the tank and one at the bottom area. The new tank (55 gal) has both connections coming out of the top of the tank, not the sides. Is there a way to extend the current lines by using couplers or extensions?
http://i66.photobucket.com/albums/h2...t/DSCI0454.jpg
sirgknight is offline   Reply With Quote
Old 04-11-2012, 11:16 AM   #2
the Musigician
DangerMouse's Avatar
Is the new one going to be gas or electric?
Some things I see in that picture do not seem right to me..... but it's a mobile too.... Guys?
DM
Old 04-11-2012, 12:11 PM   #3
I'm total electric, and I'm very novice when it comes to this kind of plumbing, but this was my initial thought......Take two short 3/4" pieces of galvanized pipe threaded on each end....attach the existing water lines to one end of the pipes....then attach new flexible copper lines, let's say 18", to the other ends of the pipe and connect the new line to the water heater. Is this a workable solution? By the way, the water heater is in its own enclosed closet so there's no chance of anyone accidentally touching the hot line.
Old 04-11-2012, 01:47 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Your new water heater is not rated for mobile homes, return it and get the correct model. Also do not connect with galvanized, it will cause galvanic action and corrode quickly.
Coastal South Carolina
Old 04-11-2012, 04:53 PM   #5
OK....thanks!
Old 04-11-2012, 05:12 PM   #6
A "Handy Husband"
rjniles's Avatar
Here is a mobile home rated WH:
All the one I have seen have the side mounted water connections.
http://www.homedepot.com/Plumbing-Wa...&storeId=10051
Old 04-11-2012, 06:13 PM   #7
That would make a change-out very simple, and we have a home depot fairly close to us. Thanks.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Twin Water Heaters Installed BigD9 Plumbing 6 04-08-2012 02:06 PM
Efficient water Heaters zootjeff Plumbing 5 05-27-2011 02:50 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
