Changing Toilet Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2013, 10:27 PM   #1
Hey guys, I'm a new homeowner trying to remodel a small half bathroom. Unfortunately I've run into something I'm not familiar with. I want to put in a new toilet but whatever kind of line this is, it doesn't reach the tank of the new bowl as the new toilet is a little higher than the old one. I want to change to a braided flexible line but I'm not even sure what kind of line this is. Any ideas? Here's a pic.
I tried to unscrew the small nut at the base of the grey line but it seems to go down into the larger nut below it.
Please forgive my lack of knowledge on the subject, I'd rather learn something new and save my money than call a plumber and pay to have something done for me that is quite possibly simple to do myself.
Thanks.
Wolfson is offline   Reply With Quote
Old 03-15-2013, 10:32 PM   #2
Rewards Points: 232
looks like some kind of home made line. Looks like someone modified it a bit.
jmon is online now   Reply With Quote
Old 03-15-2013, 10:37 PM   #3
Rewards Points: 232
Looks like its been leaking as well. Did you try 2 wrenches, one on the big nut to steady the pressure and one on the smaller one (ccw). Spray a little pentrating oil on there and tap it few times let it set for awhile. You don't want to use just 1 wrench you may break it. Be careful, it looks pretty old and rusty.
Old 03-15-2013, 10:44 PM   #4
Well what originally happened was the toilet wouldn't fill with water in the tank all of a sudden. So since I had an identical toilet in the basement I decided to swap toilets out but apparently the new one is a little higher because I can't get a tight fit with that line to the bottom of the tank. It just leaks like crazy. I've just never seen this kind of line before, I'm only familiar with the braided flexible ones. Now I want to just want to put a whole new toilet in but I'm not sure how to remove that grey line that's in there right now. I saw something similar at home depot this evening, I think it's this: http://www.homedepot.com/p/t/1001295...1#.UUPVfBdOS6U
Old 03-15-2013, 10:46 PM   #5
Rewards Points: 232
Does that smaller nut look like it's screwed onto the larger nut somehow? Or is it just one big nut soldered or threaded onto the copper pipe? Can't really tell by picture, it's a little cloudy.
Old 03-15-2013, 10:46 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
That looks like a PEX or poly B supply line.
Your best bet is to get a copper mini pipe cutter and cut the 1/2" supply line below the valve. Clean up the pipe and install a 5/8" compression by 3/8" compression straight stop. From there use a braided supply line.
Of course to do all this- you'll need to shut the water off at your main house valve.
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (03-15-2013)
Old 03-15-2013, 10:52 PM   #7
Thanks for the replies guys. So basically I just want to cut the whole dang thing off and just install a new stop altogether.
Old 03-15-2013, 10:52 PM   #8
Rewards Points: 232
yea, that's pex line. They are commonly used for that purpose, because you can make them any lenght you need. I agree with you, I like the braided ones better.
Old 03-15-2013, 10:53 PM   #9
Rewards Points: 232
That's correct. It will look a lot more professional as well.
The Following User Says Thank You to jmon For This Useful Post:
Wolfson (03-16-2013)
Old 03-15-2013, 10:56 PM   #10
Plumber
Rewards Points: 452
For me, that would be the simplest. Be sure you read up on installing a compression stop
Or you could wrestle with that nut for a while.
If it comes off- can you not just pull the old supply line out then replace it with a 12" flex?
Old 03-16-2013, 12:25 AM   #11
Well, turns out this thing just pulls right out. First time I've ever seen this personally. Here it is.
Old 03-16-2013, 12:37 AM   #12
Plumber
Rewards Points: 452
Sounds like all you need is a longer flex now
Old 03-16-2013, 08:58 AM   #13
Roofmaster
Rewards Points: 2,172
That valve was new about when Hitler was in power.
Shut off the main. Flush the toilet. Buy a close quarters pipe cutter, a straight compression supply valve for 1/2 inch copper, some fine plumbers emory, and a SS braided toilet supply. Clean up the pipe like a shoeshine boy just under the valve, all around. Do not sand in line with the pipe. Only shoeshine style. then cut the old valve off, loosen the nut to the toilet and throw away the gray pipe valve and nut. Put the compression nut on the pipe cup side up, slide on the ferrule, set and bottom the new valve, and while holding, screw the compression nut to the valve body. A little light machine oil on the threads helps. Put a hold back wrench on the valve body, and tighten the compression nut to just a little over snug. This forms the brass ferrule to the valve seat. DO NOT CROSS THREAD, and DO NOT OVER TIGHTEN. Install new braided toilet supply. Note: Toilet supplies are different from sink supplies.
Good Luck.
The Following User Says Thank You to jagans For This Useful Post:
Old 03-16-2013, 12:54 PM   #14
Thank you, that's exactly what I'm going to do.
Broken underground supply line Eds_tls Plumbing 2 07-26-2012 07:07 PM
Supply Rough In for Toilet dvation191 Plumbing 9 12-27-2011 12:42 PM
Bathroom sink supply line leak afarr Plumbing 6 05-26-2010 06:59 PM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 12:26 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 07:55 PM
