Changing Out The Stand Pipe... - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2014, 08:34 AM   #1
Rewards Points: 97
Changing out the stand pipe...
Need to change out the stand pipe for the washing machine and reroute to a washing machine outlet box.
It looks like the chrome stand pipe is lead-welded to the (galvanized?) elbow,
which is treaded to the nipple from the tee.
The threaded close nipple from the tee seems to be rusted (the tee is also rusted). Is it still good to reuse and connect to an ABS female adapter? Or I'd need to attempt to change out the nipple also?
When connecting an ABS female adapter to a galvanized nipple, would Teflon tape be good enough for a leak-free hookup?
joemc3 is offline   Reply With Quote
Old 04-08-2014, 08:51 AM   #2
Rewards Points: 12,802
Should be considering getting rid of all that old steel pipe not just that one line.
It's all going to leak at some point and closes upon the inside from rust.
jmon (04-08-2014)
Old 04-08-2014, 11:03 AM   #3
Rewards Points: 142
IMO, it would be easier to remove as much of the old galvanize pipe as possible and replace it with PVC. You're going to reroute it to a new washing machine outlet box anyway. You have it all opened up, now's the perfect time to do it. It wouldn't take that long to redo it. PVC is cheap and lasts a long time. We have excellent plumbers on this forum who can help you out if needed. Just a thought.
Stay tuned, the plumbers will be along shortly with more advice/suggestions for you. Thanks.
jmon is offline   Reply With Quote
Old 04-08-2014, 01:10 PM   #4
Rewards Points: 97
Thx--need the specific details to know exactly which joint, etc. to remove (and how).
The tee connects to the vent up to the roof and also down to the drain pipe under the concrete I believe. That's the part I need to figure out what to do.
Old 04-08-2014, 08:01 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If you decids not to rip it all out, remove the nipple and use a ABS or a PVC male adapter. Plastic female adapters often will crack when a metal pipe is inserted.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
TheEplumber (04-08-2014)
Old 04-09-2014, 12:29 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 348
I can't see what's under the tee but I'd look at cutting the riser just below it.
Then use a shielded transition coupling to convert to ABS or PVC drain pipe- rough in the laundry per your local code.
Treat the vent pipe the same way- cutting it up high and transition to plastic with an approved shielded coupling.
As mentioned- it's best to remove as much cast iron or galvanized pipe as possible. It's lived it's life and will fail at some point.
Old 04-09-2014, 02:02 PM   #7
Rewards Points: 97
Here are two close-ups.
Cut the galvanized pipe from the bottom drain half way up and remove the tee, then use Proflex couplings to change out to ABS (leave the top galvanized vent untouched)?
remove the nipple...
That close nipple seems a bit tricky to remove. If I were to do this, might as well cut out the tee cleanly and use Proflex coupling... .
Old 04-09-2014, 03:57 PM   #8
biggles's Avatar
cut the drop down line elbow then unthread the that galvanized elbow into the riser...clean it up then PVC it out to the new location
Old 04-09-2014, 07:44 PM   #9
Plumber
Rewards Points: 348
That's what I'd do- you can remove/replace the gal. vent too if you want.
I don't think that nipple will come out...
If you really want to get industrious- you could remove the vertical line out of the cast iron hub at floor level, install a rubber doughnut into the hub and build ABS out from there. But sometime those hubs crack- then your screwed....
Old 04-10-2014, 01:19 AM   #10
Rewards Points: 97
I noticed the following:
The elbow out from the tee is 1.6" OD.
The vent pipe is 1.6" OD.
The chrome pipe is about 1.55" OD.
The outlet box I bought has an opening of 2.3", so it looks like it's meant for a 2" pipe size.
If I'm changing out to ABS, I wonder about the following:
Vent pipe to the roof: 1-1/4" ID ABS
1. Sanitary Tee : 1-1/4 or 1-1/2 for the output to the P-Trap?
2. P-Trap : 1-1/4", or 1-1/2" ABS?
What is the correct height of the P-Trap (any code requirement?)
3. Need a 2"->1.5" reducer going out from the outlet box?
OR,
do I need to change out everything to 2" pipe size? If so I wonder how to change out that bottom cast iron female adapter that comes out from the concrete base... .
Old 04-10-2014, 09:14 AM   #11
Plumber
Rewards Points: 348
Today's code require's 2" or 3" drain line and 11/2" vent for a washer box.
To be compliant, you should install a laundry sink instead and discharge the washer into it.
The sink takes a 1.5" drain which is your current set up
Old 04-10-2014, 09:43 PM   #12
Rewards Points: 97
So just cut the chrome stand pipe short and have the laundry sink drain feed into it? Wonder how to couple those two... .
how to build a extension shelf on the side of a changing table alpdog14 General DIY Discussions 4 09-17-2013 06:54 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
Changing Roof Type Iconoclast Building & Construction 13 07-29-2011 12:15 PM
changing svc panel, not upgrading amps hilltop Electrical 8 06-13-2011 12:04 AM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General DIY Discussions 11 01-07-2011 06:43 PM
