Old 02-09-2011, 04:48 PM   #1
Changing out fixtures
I am replacing the shower and tub fixtures from a 17 year old Delta to a Price Pfister. They are both single handle.The shower diverter on the current fixture is incorporated into handle unit (It's a valve that you pull out or push in to activate.)
The new fixture has the diverter on the tub spout
My question is: Can I simply remove the integrated shower diverter and replace it with a pipe extension and then install the spout model? The can is the hard part because the fitting is below the opening. can this be done?
shark_37663 is offline   Reply With Quote
Old 02-09-2011, 05:07 PM   #2
For what it is worth, I would much rather have a 17 year old delta tub valve than a brand new price pfister any day ever. That being said, do you realize that the push-pull diverter valve is part of the tub/shower valve that you are going to replace? It should go away when you pull the old valve out.
broox is offline   Reply With Quote
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 04:36 PM
CFL bulbs permitted in partially enclosed fixtures in closets? Cmudr1 Electrical 14 03-04-2010 10:20 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 05:08 PM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 03:42 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
