Changing Out Carpet For Tile - Toilet Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2012, 09:12 PM   #1
Just a DIY guy
Changing out carpet for tile - toilet flange?
We are remodeling our guest bath, it has just a toilet and sink. We had an under-slab leak, so it seemed like the right time.
The bathroom had carpet, which has been removed since it was soaked. We have not yet removed the toilet, but I assume the toilet flange is mounted to the concrete slab, since there is nothing else there!
We are going to tile the floor.
Question: Do we leave the flange in place, tile up to the flange, then set the toilet on top of the tile? Will we need an extension to compensate for the tile height?
Or
Do we mount the toilet on the concrete and tile around it?
I'm leaning towards the first option since you can change toilets without having to re-tile, but I'd like some expert thoughts here.
I know the "on top of concrete" vs. "on top of tile" flange debate rages on, but this is slightly different (I think) due to the already-installed flange.
M3 Pete is offline   Reply With Quote
Old 02-16-2012, 09:18 PM   #2
Rewards Points: 582
Or
oh yes it rages on..imo just tile up to the flange...this will be fine ...my need thicker wax ring ...but thats all...ben
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
oh'mike (02-17-2012), plummen (02-16-2012)
Old 02-16-2012, 09:47 PM   #3
Rewards Points: 616
Ben is correct also may need longer johnny bolts
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
ben's plumbing (02-16-2012)
Old 02-16-2012, 10:53 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
When you replace the bolts use the 5/16" versions.
Normally Ill buy an extra set of closet bolts and use an extra washer and nut on each side to anchor the closet bolts onto the flange before installing the toilet to keep them from spinning if you ever need to pull the toilet.
Then install the toilet over the top of the studs using the other washers/nuts
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (02-17-2012)
Old 02-16-2012, 11:20 PM   #5
Rewards Points: 616
worried about spinning johnny bolts i started using these it was hard to at first just hard to change from brass but know all i use no spinning to worry about no corroding and easy to cut "especially with a cordless multi tool
http://www.siouxchief.com/Specialtie...-Perfect.VGC48
The Following 2 Users Say Thank You to jaydevries For This Useful Post:
ben's plumbing (02-17-2012), plummen (02-16-2012)
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 11:45 AM
Toilet Flange cody21 Plumbing 10 09-08-2009 03:31 PM
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 06:51 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 08:40 PM
