Old 01-07-2007, 12:40 AM   #1
Question
Changing filter in Whirlpool whole house water filter
I changed the filter element in the Whirlpool whole house filiter (WHCF-DWHBB) but when I screwd the housiing back in, there is a nasty leak no matter how hard I tighten (I just broke the plastic wrench they supplied with the unit. The threads appear to be threaded correctly. But there is no rubber gasket sealing the main housing to the unit that holds the pipes and I fear there should be one....now it it plastic to plastic.
Any thoughts? Anyone with a similar problem?
Jim
farnamct is offline   Reply With Quote
Old 01-07-2007, 09:08 AM   #2
You are correct, there should be a rubber gasket for a seal. I cannot imagine how it ever sealed without one.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-07-2007, 11:39 AM   #3
Rember no gasket no seal To get you a couple of days you may be able to try using teflon tape to get you buy ,untill you can get a gasket.
trollmastergeneral is offline   Reply With Quote
Old 01-08-2007, 08:05 AM   #4
When you dumped the old filter out, the o-ring seal probably fell out too.
gitnerdun is offline   Reply With Quote
Old 02-18-2009, 02:09 AM   #5
Yeah there should be a rubber gasket for a seal..and just remember that gasket is important.. if no gasket don't know what really is be...
_________________
Everpure Filters
dixgomez is offline   Reply With Quote
Old 09-13-2009, 10:23 AM   #6
i think you should upgrade some rubber gasket
_________________
Refrigerator water filter
janjakk is offline   Reply With Quote
Old 09-13-2009, 10:31 AM   #7
WOW, a two year old post is still drawing answers. I hope the OP has fixed the problem by now.
Old 12-20-2012, 10:11 PM   #8
that's cuz they weren't the only one that did that. sad thing is I'd changed it over a dozen times in the past
pandelamer is offline   Reply With Quote
Whole House Water Treatment Systems HWPipes Plumbing 21 04-25-2013 09:53 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Whirlpool refrigerator: No ice or water!!! tarwood Appliances 5 11-20-2008 09:05 PM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 11:36 AM
