Old 02-09-2013, 12:01 PM   #16
Changing Bathroom Rough-in
Originally Posted by TheEplumber
vents should come off above the center line of the trap arm it's serving.
If it was me- I'd vent it at the wall as it passes under it near the door
So what you are saying vent should come off a 45 angle or center line.
handyman21 is offline   Reply With Quote
Old 02-09-2013, 12:02 PM   #17
call me E
TheEplumber's Avatar
Originally Posted by jaydevries View Post
depending on what code some codes say a toilet does not need venting
as long as sink is a 2 inch up to where water goes into pipe it would pass where i live
I assume the original rough in was done by the plumber during construction so it must have passed an inspection. If so, then you're right- it's already vented
Old 02-09-2013, 05:27 PM   #18
Master Plumber
Javiles's Avatar
I wish they would unify the codes posting advise would be so much easier.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
bathroom rough in help kimbhoot Plumbing 29 02-19-2013 02:09 PM
Is this correct? Basement Bathroom Rough In luapo Plumbing 9 12-09-2012 05:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Bathroom rough in shamrock_94 Plumbing 6 07-12-2008 11:33 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 10:11 AM
