02-04-2013, 10:53 PM
#1
Want to Learn
Changing Bathroom Rough-in
Hi,
I need to make some slight changes to the existing basement rough-in. The hallway outside the bathroom is to narrow to support the bathtub that the finished floor plan shows. So I'm going to make it a shower instead in order to keep a wider hallway. And I also want to move the toilet since the sump pump doesn't exist as seen in the original layout. In the image below, the piping on the left is how I think it's currently laid out from some pictures I took before the concrete was poured. So I want to break up the concete and move it a little bit. Is there anything illegal about the additional piping and turns it takes (as seen in red)?
Thanks,
Jon
02-05-2013, 08:04 AM
#2
Super Moderator
Please add your vents to the drawing-----
02-05-2013, 08:47 AM
#3
Want to Learn
I'm using an AAV (allowed by code here in Colorado). It will come off the sink. They actually have one sitting on the sink rough-in pipe coming out of the ground right now.
Here's a picture:
02-05-2013, 10:29 PM
#4
Plumber & Gasfitter
Aside from the AAV, your "new set up" would pass codes up here (assuming pipe sizes are correct).
02-06-2013, 10:29 AM
#5
Want to Learn
Thanks for the input. I think they're 3" and 2 1/2" pipes that exist right now. I'll just continue the same size that is being used since they already passed the initial inspection.
Thanks again,
Jon
02-06-2013, 03:17 PM
#6
you would need a vent on the line to the toilet.
02-06-2013, 03:57 PM
#7
Want to Learn
Can't a single large AAV support all the units?
02-06-2013, 03:59 PM
#8
JOATMON
I've always been told...."You can never have too much vent"....
You should see the vents I have on my house....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-07-2013, 10:36 AM
#9
Want to Learn
So if I want to add a vent to the toilet, where do I put it? Do I just extend the pipe past the toilet by using a T connection or something like that? A combo tee/wye type connection?
02-07-2013, 07:56 PM
#10
Super Moderator
That would work--2" vent is required--within 5 feet of the fixture---the closer the better for a toilet.
02-08-2013, 11:36 AM
#11
Want to Learn
Thanks! I was planning on a 3" vent for the toilet since the pipe is 3".
02-08-2013, 05:31 PM
#12
Why did you tell him that you can vent the water closet like? Don't you have to bring the vent off before the fixture. So you will put a wye on a 45 degree angle then the 90 for the water closet? what he said come a cross and but a tee and bring the vent off the back where can you do that.
02-09-2013, 09:14 AM
#13
Want to Learn
You're saying I CAN'T have a vent after the toilet?
Can someone else chime in since I'm getting conflicting answers now?
Thanks!
02-09-2013, 11:47 AM
#14
call me E
vents should come off above the center line of the trap arm it's serving.
If it was me- I'd vent it at the wall as it passes under it near the door
02-09-2013, 11:54 AM
#15
depending on what code some codes say a toilet does not need venting
as long as sink is a 2 inch up to where water goes into pipe it would pass where i live
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
The Following User Says Thank You to jaydevries For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
