-   -   Changing Bathroom Rough-in (http://www.diychatroom.com/f7/changing-bathroom-rough-171057/)
jonhayden 02-04-2013 09:53 PM
Hi,
I need to make some slight changes to the existing basement rough-in. The hallway outside the bathroom is to narrow to support the bathtub that the finished floor plan shows. So I'm going to make it a shower instead in order to keep a wider hallway. And I also want to move the toilet since the sump pump doesn't exist as seen in the original layout. In the image below, the piping on the left is how I think it's currently laid out from some pictures I took before the concrete was poured. So I want to break up the concete and move it a little bit. Is there anything illegal about the additional piping and turns it takes (as seen in red)?
Thanks,
Jon
http://i1292.photobucket.com/albums/...ps6d9ccf94.jpg
oh'mike 02-05-2013 07:04 AM
Please add your vents to the drawing-----
jonhayden 02-05-2013 07:47 AM
I'm using an AAV (allowed by code here in Colorado). It will come off the sink. They actually have one sitting on the sink rough-in pipe coming out of the ground right now.
Here's a picture:
http://i1292.photobucket.com/albums/...psdc1aefe0.jpg
joeplumber85 02-05-2013 09:29 PM
Aside from the AAV, your "new set up" would pass codes up here (assuming pipe sizes are correct).
jonhayden 02-06-2013 09:29 AM
Thanks for the input. I think they're 3" and 2 1/2" pipes that exist right now. I'll just continue the same size that is being used since they already passed the initial inspection.
Thanks again,
Jon
DannyT 02-06-2013 02:17 PM
you would need a vent on the line to the toilet.
jonhayden 02-06-2013 02:57 PM
Can't a single large AAV support all the units?
ddawg16 02-06-2013 02:59 PM
I've always been told...."You can never have too much vent"....
You should see the vents I have on my house....
jonhayden 02-07-2013 09:36 AM
So if I want to add a vent to the toilet, where do I put it? Do I just extend the pipe past the toilet by using a T connection or something like that? A combo tee/wye type connection?
http://i1292.photobucket.com/albums/...ps1665595d.jpg
oh'mike 02-07-2013 06:56 PM
That would work--2" vent is required--within 5 feet of the fixture---the closer the better for a toilet.
jonhayden 02-08-2013 10:36 AM
Thanks! I was planning on a 3" vent for the toilet since the pipe is 3".
best handyman 02-08-2013 04:31 PM
Why did you tell him that you can vent the water closet like? Don't you have to bring the vent off before the fixture. So you will put a wye on a 45 degree angle then the 90 for the water closet? what he said come a cross and but a tee and bring the vent off the back where can you do that.
jonhayden 02-09-2013 08:14 AM
You're saying I CAN'T have a vent after the toilet?
Can someone else chime in since I'm getting conflicting answers now?
Thanks!
TheEplumber 02-09-2013 10:47 AM
199 Attachment(s)
vents should come off above the center line of the trap arm it's serving.
If it was me- I'd vent it at the wall as it passes under it near the door
jaydevries 02-09-2013 10:54 AM
depending on what code some codes say a toilet does not need venting
as long as sink is a 2 inch up to where water goes into pipe it would pass where i live
