Changing Around Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2010, 12:57 AM   #1
Electrician
Proby's Avatar
Changing around vent pipe
I have a large copper vent pipe running thru my attic. It comes up from my full bath and runs horizontally 2" above the floor for about 15 feet to above my kitchen. There is a T there where the kitchen sink vent intersects and it goes up thru the roof.
This pipe is in the way of open space in the attic, I would like to re-route it a bit, to do this I would have to add a couple of bends. It would remain at the same height the whole way.
Can I just it and then insert PVC pipe of the same size with a pair of Fernco's at each end?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-21-2010, 01:26 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 354
Yes you can. Support plastic pipe @ 4' intervals. Maintain any existing grade and nominal pipe size and you should be fine
Old 08-21-2010, 01:35 AM   #3
Electrician
Proby's Avatar
Great, simple enough.
Since it's my thread, I get to hijack it
Today I did an electrical rough in on an attic apartment. In the bathroom I noticed the vent for the sink went up about 2', then across 2', then back down 2', then across to where it intersected other vent pipes, but it made a bunch more turns both horizontally and vertically.
This was all new work from a well known plumber so I assume it is correct. But it was just odd to see it going up and down and around, I thought a vent had to be relatively upwards the whole time and could only go so far horizontally?
Old 08-21-2010, 10:01 AM   #4
Rewards Points: 150
fernco ftgs.should only be used outside the footing for under ground use.you can get a no hub style transition ftg.that will adapt copper to pvc.
rudolph58 is offline   Reply With Quote
Old 08-21-2010, 10:19 AM   #5
Electrician
Proby's Avatar
I was under the impression that ferncos and no hubs were the same thing?
Old 08-21-2010, 10:38 AM   #6
Rewards Points: 150
a no-hub coupling has a stainless steel wrap that goes around the rubber sleeve with 2 hose clamps.
Old 08-21-2010, 12:03 PM   #7
Plumber
Rewards Points: 354
Almost sounds like an island(loop) vent. But your description doesn't quite match the way code reads. Was this piped in a half wall so the vent couldn't go vertical to the ceiling?
BTW, why were you looking at the plumbers work? You're supposed to be wiring the place
About ferncos- I didn't catch your fernco comment in the opening post. While I totally agree with Rudolph58, I am still surprised to see them on past remodels that have been signed off by the AHJ. But then, these plumbing inspectors also double as building inspectors(or is it the other way around)
Look at cast iron No hub piping in walls or ceiling sometime and you will instantly see the difference between fernco and a NH coupling
Old 08-21-2010, 12:31 PM   #8
Electrician
Proby's Avatar
Yeah, it had to go horizontally into a lower attic space behind a knee wall where it met up with other vents and then went out that low roof.
LOL I have a bit of work to do in my bathroom so I have been paying attention to plumbing.
Gotcha, thanks guys
Frozen Vent Pipe Ratchye Plumbing 55 01-17-2017 06:21 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Splicing ABS Black Vent Pipe Garfield Plumbing 1 12-07-2009 03:53 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
Gas vent pipe getting water into it jwk937@hotmail.com General DIY Discussions 2 01-06-2009 06:47 PM
