Changing Anode Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2013, 05:03 PM   #1
Changing anode rod
I have a 22-year-old oil fired Aero water heater which is working well yet has never had the anode rod changed. Should I change it now or is the risk of removal greater than the risk of just leaving it in place and forgetting about it? All thoughts on this matter are greatly appreciated.
David Mark is offline   Reply With Quote
Old 10-31-2013, 05:33 PM   #2
MarginallyQualified
Rewards Points: 2,464
What sort of water quality do you have?
At 22 years you are already beyond the useful life.
I hard to see anything being gained by messing with the install
when you're likely to need to do that anyway before too long.
iow... let sleeping dogs lie
The Following 4 Users Say Thank You to TarheelTerp For This Useful Post:
COLDIRON (11-01-2013), concretemasonry (10-31-2013), David Mark (10-31-2013), jmon (10-31-2013)
Tags
anode rod , water heater
Anode rod replacement - how often? Daneel Plumbing 8 07-07-2013 05:06 PM
another question about sulphur smell in hot water RSCHLITZ Plumbing 5 08-25-2012 03:41 PM
Question about removing Bradford & White anode rod Suzeroo Plumbing 0 04-01-2011 09:19 PM
Changing anode rod joeg679 Plumbing 23 02-15-2011 09:21 PM
Teflon tape or pipe dope an anode rod? Nestor_Kelebay Plumbing 4 02-08-2009 10:42 PM
