Old 10-29-2011, 11:33 AM   #1
Change wax ring on toilet have problem
Changed the wax ring on my toilet because it was leaking a little. When I did leak stopped, but toilet won't flush. When it does flush it bubbles up and gurgles in the shower drain. I know this has symptoms of a vent problem, but this happened when I changed the wax ring. It flushed fine before that. What's going on here?
Justinzoila is offline   Reply With Quote
Old 10-29-2011, 12:12 PM   #2
Sounds like the drain is clogged...
Billy_Bob is offline   Reply With Quote
Old 10-29-2011, 12:14 PM   #3
Tileguy
Bud Cline's Avatar
How old are your kids?
Did you shove a rag in there to stop the odor and forget to remove it?
Old 10-29-2011, 01:59 PM   #4
I took the toilet off the drain and snaked it. It flushes better but still makes a slight bubble sound in tub. I think you where right it had a clog. I think it might be still blogged a little. I didn't use a rag to cover hole. Maybe I should have.
The Following User Says Thank You to Justinzoila For This Useful Post:
Bud Cline (10-29-2011)
Old 10-29-2011, 03:05 PM   #5
Next if you can, snake the vents. Also snake the toilet itself.
Old 10-29-2011, 03:21 PM   #6
I snaked the vent, but not the toilet. I try that, thanks
Old 10-29-2011, 05:26 PM   #7
AlbacoreShuffle's Avatar
Look on the bottom of the toilet .
You may have a big ugly hunk of the old wax ring on there.
AlbacoreShuffle is offline   Reply With Quote
new toilet or replace ring bobmane Plumbing 3 12-12-2010 12:54 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 03:23 AM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 03:30 PM
