-   -   Change wax ring on toilet have problem (http://www.diychatroom.com/f7/change-wax-ring-toilet-have-problem-121695/)
Justinzoila 10-29-2011 11:33 AM
Changed the wax ring on my toilet because it was leaking a little. When I did leak stopped, but toilet won't flush. When it does flush it bubbles up and gurgles in the shower drain. I know this has symptoms of a vent problem, but this happened when I changed the wax ring. It flushed fine before that. What's going on here?
Billy_Bob 10-29-2011 12:12 PM
Sounds like the drain is clogged...
Bud Cline 10-29-2011 12:14 PM
How old are your kids?:(
Did you shove a rag in there to stop the odor and forget to remove it?:)
Justinzoila 10-29-2011 01:59 PM
I took the toilet off the drain and snaked it. It flushes better but still makes a slight bubble sound in tub. I think you where right it had a clog. I think it might be still blogged a little. I didn't use a rag to cover hole. Maybe I should have.
Billy_Bob 10-29-2011 03:05 PM
Next if you can, snake the vents. Also snake the toilet itself.
Justinzoila 10-29-2011 03:21 PM
I snaked the vent, but not the toilet. I try that, thanks
AlbacoreShuffle 10-29-2011 05:26 PM
Look on the bottom of the toilet .
You may have a big ugly hunk of the old wax ring on there.
