Change Water Heater, Need Change Gas Flex Connector? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2007, 11:04 AM   #1
sz8
change water heater, need change gas flex connector?
Just wondering gas connector/adapters can be reused. It has been
used for 10 years and is made of stainless steel (looks like it).
If it can be reused, how do you clean up the old dope for one of the
adapters before putting it on the new water heater?
Thanks,
SZ
sz8 is offline   Reply With Quote
Old 09-27-2007, 11:39 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, just a long-time DIYer, but I don't know why you cannot use existing connectors if they aren't damaged. You should be able to clean the old dry pipe dope off of the threads with a wire brush. Use fresh pipe dope and/or teflon tape made for gas (yellow), and tighten the connections well. Test the connections with soapy water for leaks.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-27-2007, 12:38 PM   #3
sz8
Thanks Mike. for the tip.
Since it is female thread, I am thinking using a small
brush to clean it. I was thinking using paint thinner
to clean it, but not sure if the dope is solvable. I may
give it a try anyway.
SZ
Good Luck!
Mike
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Flex to Water Heater darcarcr Plumbing 1 01-11-2007 07:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
