Old 01-08-2013, 04:07 PM   #1
Change Wall Hung Toilets to Floor Ones
Hi, I just bought a house with two wall hung toilets. These are back to back and use the same drain pipe. The both are very old, ugly, and leak. I'd like to replace them with floor mounted toilets. I've looked into replacements for my wall hung toilets and they seem to run around $500 each. I've never worked with wall hung toilets before. I am used to replacing floor ones. So I'm just wondering if it makes sense to spend $1000 on new wall hung toilets or get a plumber to install piping for the floor ones? Any advise would be appreciated.
ThirdBirch is offline   Reply With Quote
Old 01-08-2013, 04:20 PM   #2
I should mention that there is plenty of room in the crawl space under the house. The pipes are not in concrete and very accessible.
Old 01-08-2013, 04:27 PM   #3
Super Moderator
That is a rather big expense----new floor openings and then wall repair and paint---maybe even new floor coverings,too.
If you are planning to remodel both baths so those expenses are covered? Then ,sure,why not?
If floor and wall/painting are are not in the works--then get your self a wall hung replacement---
Go to a real plumbing supply house for the foam gaskets---sealer and nuts---most have them as a kit---
Old 01-08-2013, 06:40 PM   #4
why replace toilets just change gaskets and make sure the thimble and back nuts are set correct and they will not leak. i personally would rather have wall mounts easier to clean floor
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 01-08-2013, 10:45 PM   #5
Doing it myself
Alan's Avatar
Only problem is that residential wall hung toilets are limited in variety. If you're looking for something specific, you won't find it in the wall hung monster.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (01-09-2013)
Old 01-09-2013, 11:12 AM   #6
i doubt if you could get a plumber to do the job for under $1000
Old 01-09-2013, 01:12 PM   #7
Master Plumber
Javiles's Avatar
2 hours of jetting $795 1 hour camera $295 the look on the homeowner face when you tell him he needs a new sewer line at a cost of 9g's priceless.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
wall hung commode replacement sawsco Plumbing 2 06-01-2010 10:22 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
