Change Pipe To 3/4"... - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2014, 07:12 AM   #1
Change Pipe to 3/4"...
Hello All!
I currently have 1/2" copper coming into my house... And all my lines servicing all the faucets, appliances, bathroom, etc. are also 1/2"... But I will be adding a second bathroom right above my main bathroom... I wanted to tap into the line servicing my main bathroom and extending it to the new bathroom... I was thinking of changing all the lines from 1/2" to 3/4", then break off to service each bathroom...
Since the main line into my house is 1/2" I wasn't sure if that would make a difference... If it will make a difference changing to 3/4", should I do 3/4" starting at my meter to my water tank, etc...
markw8500 is offline   Reply With Quote
Old 02-27-2014, 08:17 AM   #2
Rewards Points: 13,724
Coming into your house from where?
Your pump house, city water meter?
Reason I'm asking is it would be far better if it was all 3/4" mains.
A 3/4"pipe will have close to twice the volume of a 1/2 pipe, but if it's only 1/2 at the beginning it's going to give you good flow and volume when a faucet is first opened but drop off quickly.
It's like standing on a garden hose.
It will be better but not the best it can be.
Old 02-27-2014, 08:20 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It won't make a difference unless you change it all the way out to the meter. There's nothing wrong with upsizing the mainlines inside the house now with the intention of upsizing the mainline later.
Journeyman Plumber
Old 02-28-2014, 07:48 AM   #4
Joecaption: My water line coming into my house is from the main city waterline which is also 1/2"...
In a nutshell... It goes:
Main City water line-> 1/2" copper pipe into my house-> Water Meter-> Pressure Regulator-> Fuel House...
Alan: My meter is inside my house... But the line from the main city waterline to my meter is still only 1/2"... Will it make any difference beside what Joecaption said?
That is also a good idea about changing my lines inside my house with the intention of upgrading later...
Old 02-28-2014, 08:40 AM   #5
Rewards Points: 1,256
Depends on the pressure. 60# plus probably not. 35# possibly.
Old 02-28-2014, 10:04 AM   #6
Ok... Right now my pressure is about 50lbs...
Old 02-28-2014, 06:10 PM   #7
Rewards Points: 1,952
Wow, smallest water feed from street in these parts is 3/4 inch..
Old 02-28-2014, 06:15 PM   #8
Rewards Points: 582
well if your pressure is about 50 psi now and you have pressure regulator in the system.....you could bump up the pressure and run the 3/4 lines which would carry more volume and adding the little higher pressure you should improve your demand ....ben sr
Old 02-28-2014, 06:21 PM   #9
It wouldn't hurt... 3/4
Old 03-01-2014, 01:09 PM   #10
Ghostmaker: You're not kidding! My house was built around 1890...
Ben: AWESOME! I think that's what I'll do... What pressure do you think I can turn it up to?
Old 03-01-2014, 03:03 PM   #11
Rewards Points: 582
see if you can get 65- 70 start there and see if its good enough...ben sr
Old 03-01-2014, 03:14 PM   #12
Ok... Great! Thanks Ben!!!
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
Can I go up from 3/4" metal gas pipe to a 1" and then back down? Philip_Soldat Plumbing 3 11-09-2009 09:47 AM
