Change Lavatory Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2011, 01:13 AM   #1
condast
MOEN TWO HANDLE LAVATORY FAUCET MODEL 84000 & 4500 SERIES -
The cold water handle turns clockwise to open and counter-clock to shut
off and that is COUNTER-INTUITIVE!! I hate to have to think to wash my hands!
Can I install a replacement cartridge that works normal (or just rotate the
present cartridge 180 degrees)?
Help
Wannabeawashernotathinker
condast
condast is offline   Reply With Quote
Old 03-09-2011, 07:38 PM   #2
Rewards Points: 77
thats how its supposed to go. did you make a mistake in your posting? did you mean the hot handle does that? cold is clockwise on, towards the spout and counter clockwise off, towards the wall.
bryan1282 is offline   Reply With Quote
Old 03-09-2011, 07:59 PM   #3
condast
Faucets
In our house both kitchen and bath, hot and cold, have been counter-
clockwise on and clockwise off til now - the new Moen is clock-wise on
for the cold and we are not used to it, so I guess basically I can get and
install a new cartridge if I want, right? (Just checked other half-bath and that
lavatory goes the opposite direction for both hot and cold but they have
the one directional handles that intuitively you twist the direction you need.
Old 03-09-2011, 08:18 PM   #4
Rewards Points: 77
ohhhhh ok. so both hot and cold are counter clockwise on and you want to keep them all that way. you can get a hot stem and install it on the cold side. usually the cold stem turns on clockwise and the hot stem counter clockwise to turn on, so a hot stem on the cold side would be counter clockwise to turn on. double check whereever you go of course if the stem is for hot or cold.
Old 03-09-2011, 08:21 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
Handles are parallel to the wall when off, turn toward the spout to turn on
Tags
faucet , moen , plumbing fixtures
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 02:13 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 09:29 AM
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 04:32 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
