Certain Type/brand Of Pipe Dope To Use - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2012, 05:18 PM   #1
Rewards Points: 87
certain type/brand of pipe dope to use
I am repairing a leak in a sink supply and going from older galvanized pipe to wirsbo pex.
Is there a certain type and/or brand of pipe dope I should use where my brass adaptor will screw into the existing galvanized pipe?
hellonoko is offline   Reply With Quote
Old 09-06-2012, 05:32 PM   #2
Rewards Points: 14,306
As long as it says Teflon pipe dope it will work.
You do know at some point all the old galvinized pipe is going to have to go, right?
It's going to leak, close up on the inside reducing flow, the flaking off rust is going to plug up your faucets.
Old 09-06-2012, 05:33 PM   #3
Rewards Points: 87
@joecaption - thanks, yea it will all be replaced at some point but for now I just need to fix this little leak.
Old 09-06-2012, 05:45 PM   #4
If it was mine I would first use a couple of wraps of teflon tape then the dope.
Putting steel in direct contact with brass is never a great idea.
It will cause corrosion.
Old 09-06-2012, 05:54 PM   #5
Rewards Points: 87
That is actually what the wirsbo supplier suggested I do. Tape then dope. I will do it that way. Thanks.
Tags
pex , wirsbo
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Teflon Tape or Pipe Dope Jupe Blue Plumbing 3 05-21-2011 09:17 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
