Central Heating Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2011, 06:09 AM   #1
Central Heating problem
my boiler keeps turning itself off within 5mins of turning it on pressure is ok what could prob be???????
Sparks1900 is offline   Reply With Quote
Old 11-17-2011, 11:10 AM   #2
how
Rewards Points: 1,104
What part of the boiler is turning itself off. Pilot, Burners, Pump etc.
Not enough of an explanation.
You should consider the HVAC site for info on this as well.
how is offline   Reply With Quote
Old 11-17-2011, 12:02 PM   #3
biggles's Avatar
if it is a boiler for hot water baseboard with a circulating pump it is controlled by temperature limits check those TYPICAL 150F-160F.if it is that type...if it is a actual boiler with radiators it then is pressure controlled 5PSI control check that setting....and water level control if it has one....what type of home hi-ranch one level...let us know
radiated heating system problem worthspending Plumbing 2 02-20-2010 07:32 AM
how often to schedule maintenace on central a/c heating grappler777 HVAC 3 01-08-2009 09:46 PM
Central Heating Problem BackBoiler488 Plumbing 4 12-30-2008 12:31 PM
Central heating unit not blowing air SoCalRailFan HVAC 8 12-27-2008 07:32 PM
Central Heating Frustration SassySue General DIY Discussions 4 11-29-2007 06:46 AM
