-   -   Central Heating problem (http://www.diychatroom.com/f7/central-heating-problem-123741/)
Sparks1900 11-17-2011 06:09 AM
my boiler keeps turning itself off within 5mins of turning it on pressure is ok what could prob be???????
how 11-17-2011 11:10 AM
What part of the boiler is turning itself off. Pilot, Burners, Pump etc.
Not enough of an explanation.
You should consider the HVAC site for info on this as well.
biggles 11-17-2011 12:02 PM
if it is a boiler for hot water baseboard with a circulating pump it is controlled by temperature limits check those TYPICAL 150F-160F.if it is that type...if it is a actual boiler with radiators it then is pressure controlled 5PSI control check that setting....and water level control if it has one....what type of home hi-ranch one level...let us know
