Old 01-07-2009, 06:43 AM   #1
central heating boiler leacking from relieve valve
Help please.
I have a Alpha SY24 wich was leacking from the relieve valve.
But every time I was filling the system at cold to 1bar, as soon the water was getting hot the pressure build up to 2.5bar
At some stages the system was loosing its pressure from the relieve valve to 0bar, so I thought to replace the releieve valve to solve the problem.
But it keeps doing the same thing with the new valve.
Is the expantion vessel the problem.
Please advise.
ladybreaker is offline   Reply With Quote
Old 01-07-2009, 08:34 AM   #2
Tom Struble's Avatar
is it possible the fill valve is not shutting all the way?
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 09:00 AM   #3
check the expansion tank ,if all hot then water log .pressure in tank should be 12psi .drain the tank. that should do it
metx is offline   Reply With Quote
Old 01-07-2009, 01:37 PM   #4
The filling loop is removed every time I fill the system.
I will chek the expantion vessel pressure
Thanks to all
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
hot water and central heating wont work independently khanay Plumbing 2 07-12-2008 04:14 PM
Central Heating Frustration SassySue General Discussion 4 11-29-2007 07:46 AM
Central heating 3 way valve KevinO Plumbing 1 05-11-2005 12:09 AM
